cast aluminum brackets
Lynds
I'm trying to find a place to purchase those cast aluminum backets that used to be at the stern and bow of the old Princecraft Aluminum boats. The ones on the stern corners extended to form handles. The one on the bow was triangular in shape. I"m not doing a very good job of describing them. Anybody have an idea of what I"m talking about or where I could find them?
thanks,
Lynds
Re: cast aluminum brackets
I've tried contacting them and have not been able to find a way that gets a response. I've now found a dealer and after two attempts, still haven't received a reply. I contacted the dealer again today and hopefully I'll get some kind of answer.
thanks
CATransplant
I hope you have luck, but figure on those castings not being available for any boat more than 10 years old.
Are yours just missing, or are they broken?
If they're missing altogether and unavailable, you can do several things to replace them.
You can buy solid aluminum sheet material, 1/4" thick, at any metal supply house. You can cut this into whatever shape you need, then attach it to the gunwales and transom of your boat with suitable hardware. Most of the suppliers will cut it for you, if you tell them what you need or provide simple drawings.
Handles can be purchased, too, and through-bolted to the transom. Get heavy duty handles at your local hardware store. You can probably even get stainless steel ones. If you're in fresh water, you can just use stainless steel bolts and screws.
Most likely, the cast braces won't be available for your boat, but you can make new ones that will be even better.
Aluminum angle iron, available at your local hardware store, can strengthen the gunwale to stern braces. Put it under your 1/4" plates on the sides and transom, and you'll have something even stronger and more indestructible than the original castings.
