Catfishing Season 2013 open discussion and photos
River_Lizard
Just thought I'd start a new topic on catfishing for 2013.
Here's my run down:
Boat: 24 ft Harris pontoon w/90 johnson
River: James River in Virginia
Bait: Gizzard Shad, Thread fin shad, Crappie (cut bait and live also) taken by Gill Net other than Crappie (rodNreel)
Reels: Tidewater 30's
Line: 80 lb braided yellow
Swivels: 275 lb
Leaders: custom 225 lb 7 stranded steel cable
Hook: 12/0 SS circle hook
Target Fish: Blue catfish from 30 to 100 lbs
Fishing season: Year round
Largest cat: 68.4 lbs
The above set up is what I use to target big catfish, these items are not something you'd use if the average catfish size is 35 lbs or less. I would recommend sizing your tackle to around 80% of the largest catfish that's been caught in your area. (example: If the record in the area is 80 lbs then scale back your tackle for a 64 lb catfish hookup) You'll notice that I'm fishing with 80 lb braid which is probably the weakest link other than the drag system on my reel which is probably 12-14 lbs. Either the fish is going to spool my reel or break the line but with 225 yds of line on my spool I highly doubt a catfish will spool it so it all ends up on the 80 lb line I have.
Bait is a subject that has thousands of answers, it depends on many things, what type of catfish you're targeting, what body of water you're fishing, what the typical bait fish is for that body of water, etc... The list goes on and on...sometimes the Blue catfish likes live bait, other times cut bait. Size of bait plays a role in it also, at times the Blues on the James will eat a whole Gizzard Shad that weighs 2+ lbs whole, other times they like smaller cut baits.
If you're targeting BIG cats, my suggestion is use bigger baits than normal. You won't get as many bites but when you do get a bite chances are your rod tip will slam down and you'll be in for a good fight. I've fished for 4 hrs without a bite and then BAM.....61 lber hit the bait. Some people put 1 or 2 large baits out and then fish with smaller baits on the other rods so they can fight some fish while they're waiting for the larger ones to bite. I'm not one of those people, I set mine up to fish for big fish, I set the clicker, set the drag to assure that the circle hook with set when the fish takes off and then I kick back......take a nap or read a book while I wait.
Blue catfish move...so just because you caught them last weekend on a certain drop off doesn't mean that they'll be there again the next weekend. If you're not getting any bites deep channel, move to a drop off and if that doesn't work, move to a flat. Give a spot at least 30-40 minutes then move if no bites.
Don't drop your anchor.....lower it into the water slowly and shut your engine off as soon as possible. The more you drive over the spot you're fishing or making additional noise the more the catfish will be spooked. If I have to motor over a spot several times I'll mark it on the GPS and come back to it later to fish it.
Blue catfish love 38-44 degree water temps and are really active in the James river during those temps, which can be between Nov. thru Feb..
I can't tell you much about Channel cats other than I like using cut Bluegill for bait and a croaker rig for a setup.
As far as Flatheads, live Bluegill is the best bait for fishing for them and fishing brush piles is one of the best spots to find good FHs.
Here's a 42 lber I caught Jan. 13th, 2013 on the James...drifting cut bait in 12 ft. of water.
mesajeeper
Re: Catfishing Season 2013 open discussion and photos
Wow, thanks for the info. Here in Arizona we don't have any Blues but we have plenty of channels and flatties. I will have to lookup the croaker rig as I don't know what rig that is, or maybe I call it something else. Anyways, thanks for sharring and I hope this thread get's some action.
River_Lizard
MesaJeeper,
I'll look to see if I can't find a photo of the rig and post it up today. Not sure what you're regs are on double hooked leader rigs? Might not be able to use them in your state.
Try doing a search for "Eagle Claw Top and Bottom Rig" It's a good rig to drift. when I fish with them I keep them just off the bottom and drift with them. Biggest cat I've gotten with this setup is a 32 lb Blue and a 4 lb Channel.
NealLauderman
Good information and thanks for sharing! Were not far from one another. I am in Fburg.
River_Lizard
Neal,
You've got some great catfishin' waters at the Potomac....that river is on fire when it comes to Blue Catfish...it's gonna put the James River to shame pretty soon. It's too bad that Maryland DNR is so against Blue Catfish.
I'd love to fish it.....but I just can't bring myself to tow my pontoon all the way up to the Potomac when I'm 4 miles from 2 ramps on the James.
NealLauderman
Dang Jeff, that is good news to hear. The potomac is a little scary for me though. I only have a 16' wide jon boat with a 25hp tiller on it. So I dont like going too far in it as I have seen the Potomac go from glass to pretty large swells in a matter of minutes. I hear the Rappahannock is good too but they run a lot of trot lines from what I hear.
River_Lizard
Pamunkey is good, it just doesn't have the numbers like the James or Potomac does. There's a few people I know who fish the Rapp..but again, it's not like the James or Potomac as far as numbers of big fish. I completely understand the issue with wind and the Potomac....15 mph winds will make you start thinking about heading to the ramp asap. Just too much water surface area with nothing to block/slow down the wind and waves. I used to take my 16' V bottom Fisher out at West Point and that was bad enough when the wind got above 20 and the Potomac is alot bigger than just down from West Point.
If I hear of any leads on where the cats are biting on the Rapp I'll PM you and let you know. I've never fished it for Catfish.
NealLauderman
Sounds good River! Thanks! Plan to hit the Potomac a little further up towards Woodbridge at some point this year. Maybe try a little bowfishing too :p
catfishcarl99
here in il im about ready to hit it. i fish a 5000 acre cooling lake. a long narrow flooded creek channel thats chalked full of chasnnel cats and flatheads. no blues unfortunatly. but last season i boated 173 cats. not per my boat. that was just me. i love catfishing and have been a member of an online catfish forum since 2004. i do fish for other species but catfish primarily. cut fresh shad is what i use on most trips. i get fresh live lake bait every time. for flatheads i use live bluegills and sometimes get large channels on the heads of bluegills. ive not been out yet but in the next couple weeks definatly. i use ugly sticks and abu reels alot. baitcasters are preffered. circle hooks are my main hook of choice.100_1347.jpgPICT0875.jpg20.jpg
17' aluminum spectrum fish and ski
50 hp force.
heres my leds i use. installed last summer. love them.
