Re: Cauberator Rebuild - Should I attempt myself?
I think that either you are not starting it correctly, your choke is stuck, either open or closed, or the fuel pump needs a new diaphragm. OR all of these.
First, replace the diaphragm on general principals--it only costs about 3 bucks.
Second, to start the engine cold,make sure the control handle is put in fast idle/warm-up position.
Third, check the choke butterflies or the enrichment valve--whichever one it has for correct operation.
Now here's the reasoning: When cold,the engine need more gas to start. If the chokes are sticking open, or if the engine is not put into fast idle/warm-up, then it won't get that fuel and will take forever to start. Once warm, she will start with the first bump of the key.
A pinhole in the fuel pump diaphragm will leak gas into --at the very least--center cylinder. During full throttle operation, the engine can use the extra fuel but at lower speeds, it will flood and eventually stall.
NOW:The low speed circuit on the carbs consists of the narrow brass dip tube, the low speed needle (front top of the carb or at an angle at the top) and several metered holes in the casting at the butterfly. This circuit functions from idle up to about 2000RPM where the main venturi starts to work. As the butterfly opens, more of the metered holes are exposed to manifold vacuum so more fuel is delivered to meet the engine's needs. If these holes are partially clogged, the engine will not run correctly at intermediate speeds but will run fine at full throttle.
SO: If replacing the diaphragm and the above checks have not solved the problem, then it IS time to remove and clean the carbs.
You can do all the repairs yourself; it only takes hand tools and not much mecanical skill. Then follow the instructions on the top of the page under FAQ Synchronizing timing and carbs. basically a couple of hours work and a couple of bucks. Rebuild kit almost certainly not necessary.
