cpo1
Thread starter- Joined
- Apr 24, 2010
- 54
Moving along with my top cap removal on a 1977 16' Chrysler Pro Bass Runner. All rivets and screws are now removed. Both sides are fully free and moveable. All four (tri-hull) corners are caulked. I have the rear starboard corner released, but the rear port is stuck in one area. I've worked at it, but still no luck. Any ideas for breaking this loose? I have a block and tackle connected above and a hydraulic jack on the floorboard under a compound curve area. I jack very cautiously, listening for any cracking noises and/or other signs of too much stress. I also applied heat to the area, which I know is not a good idea. Here are a couple of pictures showing the stuck area, 2-3 inches wide I'm guessing. The stuck area is right next to the wood wedges on top of the transom. May have to cut and re-glass. Thanks for your help.
