Causes of Mid-Section Squeals/Squeaks?
MotorlessCSJ16
I've made numerous posts and no-one has helped me yet. :(
I hate to clutter the forum but I know it has a good reputation of having numerous very knowledgeable people.
Anyway I have a squeak/squeal that occurs when I come off WOT runs and lasts for a while until dwindling away. It sounds as if it's coming from the mid-section or possibly lower unit and I'm 95% sure it's not from the powerhead.
The motor runs great at all RPM (although I run decently rich at idle so it's a little rough).
I've heard bearing failure and what-not are possibilities but what are some tell-tale signs of a bearing failure? Does this issue even seem like it could be a bearing?
The motor is a 1998 Mercury 25hp tiller.
Any help would be greatly appreciated.
Jay101379
Re: Causes of Mid-Section Squeals/Squeaks?
Greetings...I've got the same problem you describe with my 1995 75 hp. Merc. If you run WOT for a while then back off to an idle it sounds almost like a fan belt squeaking under the cover. It does it for maybe 2-3 minutes then slowly fades away. I run it in salt water and I do flush it regularly. Did you ever figure out what the issue was with yours? Thank you.
woody66912
Motor, if this is 4 stroke, it will be the base gasket. There was a service bulletin on this. the exhaust back compression caused the metal base gasket to make a squealing noise, the fix for this was to pull the power head and drill a 3/8s relief hole in the back port side of of the gasket. The area to drill was roughly
3'' by 4''. And yes you can reuse gasket.
Jay101379
My 75 hp. is a 1994 2 stroke...a bearing issue would make sense, regardless it's definitely something creating friction that's making the noise. I'm hoping someone will chime in who's experienced the issue and found a solution!
