Stickler
- Joined
- Feb 5, 2012
- 117
So ,today i opened up the power head,as soon as i split the case i noticed water droplets and milky residue, i removed the crankshaft and pistons and this is what i found
the pistons are scored,the lower crank journal is blue from getting too hot,and the cylinders have light scoring.
Im not to sure what to do now, dont really want to put any more money into parts, pistons, crankshaft alone is likely to be 100$.So i wonder if i just clean really well and reassemble and see how she goes, and if i do that will it be ok, or do i just have a time bomb waiting to go off.It had great compression,only reason i took apart was because im compelled to take things apart and put back together,now i wish i hadnt seen this, but glad i did, im restoring this motor and this is bothering me, was this all caused by an overheat? can the crank be reused, its not scored,just discolored,put it on v blocks and dial indicator shows its straight and true, big question is, do i need a new power head, had i not torn it apart i would have assumed it was good to go,any advice appreciated
Stickler
the pistons are scored,the lower crank journal is blue from getting too hot,and the cylinders have light scoring.Im not to sure what to do now, dont really want to put any more money into parts, pistons, crankshaft alone is likely to be 100$.So i wonder if i just clean really well and reassemble and see how she goes, and if i do that will it be ok, or do i just have a time bomb waiting to go off.It had great compression,only reason i took apart was because im compelled to take things apart and put back together,now i wish i hadnt seen this, but glad i did, im restoring this motor and this is bothering me, was this all caused by an overheat? can the crank be reused, its not scored,just discolored,put it on v blocks and dial indicator shows its straight and true, big question is, do i need a new power head, had i not torn it apart i would have assumed it was good to go,any advice appreciated
Stickler
![photo[2] (2).jpg photo[2] (2).jpg](https://forums.iboats.com/data/attachments/160/160342-bd9c23fea4cec16f5874a1c491c049b6.jpg)
![photo[2].jpg photo[2].jpg](https://forums.iboats.com/data/attachments/160/160343-ddbf8f2b07a0282a2565b7bea373b347.jpg)
![photo[1] (2).jpg photo[1] (2).jpg](https://forums.iboats.com/data/attachments/160/160344-1bd879c560a8ca40e6c4cce99c037657.jpg)
![photo[1].JPG photo[1].JPG](https://forums.iboats.com/data/attachments/159/159961-075c0d7431aad410e7ec6357d9c2910c.jpg)
