cdi box 89 50hp
jerrywelds
Just want to make sure i am right before i hook it up, I have one black/yellow wire off the coil pack (its the longest wire on the block) i think this one is for the stop switch, i was hoping someone could tell me does this go to the 3rd left side terminal from the top. or would anyone have a pic of there terminal strip i could look at. Thank you guys
CharlieB
Re: cdi box 89 50hp
If I remember correctly, on the force terminal strip the White wire from the harness is the ignition kill wire.
Test the white wire with an ohm meter. Ign switch OFF should read, ign ON should be OPEN, no continuity.
jerrywelds
Re: cdi box 89 50hp
Thank you Charlie, your right it is the stop circut the only diff is mine is black with yellow stripe. Thank you again
