JoLin
Thread starter- Joined
- Aug 18, 2007
- 5,146
I need a guru. Tracking an apparent ignition problem. Have resistance-tested the coils individually and they match the specs in the shop manual. I'm having trouble interpreting how to test the terminals in the CDI. I think I understand the 'grid' contained in the manual (resistance readings across various combinations of leads) but the manual is unclear on 2 points...
- Ignition On or Off during testing?
- 'Over-Rev' sensor lead remains connected or not?
So far, in testing each of the 3 coil leads to the 'W' connector (for example), I'm getting consistent readings of 55 ohms across all 3. The book calls for 75 ohms +/- 20% (or, 60-90 ohms). Might a failing CDI give 'out of range' but consistent readings across all? Confusing, and at $600 I don't want to guess.
(gotta tell you, compared to the OMC manual I had for a 1996 Johnson, Yamaha's shop manual is pretty poor)
Thanks.
Thanks.
