center rolers ?
rbrown053
:confused:ok a little lost i have a 17 ft 88 trophy on a 82 hustler trailer. my question is this are the bunks supose to tak all the weight or are the center rolers sopse to help or are they just for guiding the boat on trailer. i now have a black streak down the center of my gel coat do i need to raise the bunks or lower the rolers not sure here can have a skunk stripe.
Re: center rolers ?
Ayuh,... Center rollers are for Guidance, Not carrying the Load...
rbrown053
Re: center rolers ?
ok 100% of weight needs to be on the bunks got it thanks
Gary H NC
Re: center rolers ?
Mine is setup so the rollers touch but do not take much of the weight.
Also the yellow nylon rollers are great! No skunk stripes on the hull...;)
rbrown053
Re: center rolers ?
just changed over to this trailer havent had time since i took her out the water for resto on her will be changing over to nylon not the skunk rollers
cbavier
Re: center rolers ?
IMO 98% Bunk and 2% rollers. But what would I know I have a roller trailer. ;) Ok I confess. I have had two bunk trailers. :D
H20Rat
Re: center rolers ?
Out of all the boats I've owned, the ones with center rollers were ALL a pain to load. If you weren't exactly centered, it would fall off to one side, then you would have to back up and line up again.
Mark_VTfisherman
Re: center rolers ?
Most of the weight should be on the bunks. On mine, the taper of the hull shape allows the whole hull to glide on the center rollers until it is nearly all the way to the bow stop. But about 18" or so from the bow stop the aft hull shape glides onto the bunks lifting 95% of the weight off the rollers. So I have mine set up so that some of the load (very little) is on the rollers. I have four rollers from the transom up to the prow.
When I rebuilt my trailer Designed that in: I positioned the boat on the rollers, slightly higher in the front, and then mounted and welded the bunk brackets with the bunks installed but with no carpet.
After all that was worked out, I installed the carpet- viola; the bunks take most of the load when loaded, but the rollers still take up a little weight, and the boat loads very easy. (when I first installed the carpet there was air over the rearmost two rollers. That went away after a few months.)
If you have a black streak I think that your rollers are too high and therefore have flat-spotted due to the weight of the boat being too concentrated on the keel and not enough on the bunks. My rollers leave no marks or mars, and roll very nicely.
