Re: Center stringer? Do I need it?
This is the front bow foot well. It has that foam sprayed on the under side of it. I really dont think its going back in. Im going to make the front well out of 1/2'' wood and glass it up. I would rather have it so when your sitting in the bow your feet will be on the deck instead of in this well. There was a 4-6'' gap from the deck to this well and it bowed in when stepping on it. Its cracked anyways from years of stepping there, I am going to need some type of foam to put back. i think the 2 part foam would be best in the bow.
The other piece is the transom section of the top cap. It has a little foam on it. Most of the foam was sprayed under the cap and none was put under the floor. Where would I get the spray type foam from and would it be a good choice?
