GaJeff
- Joined
- Jul 9, 2012
- 149
Re: Center stringer? Do I need it?
Thanks, they didn't look stainless. And they shriveled up to nothing in the middle. When I had my outdrive off last year to replace the bellows I set the bell housing on the table to clean it up and kinda knocked it off and to the ground. Well I bent one of the studs. I have plenty of zinc bolts in the bolt bin and replaced the stud with a bolt. After about 3 runs the head started to rust. I go mainly in salt water so it didn't take long. Also from a little research, I found that I'm missing a few continuity wires and the springs for the trim ram bushings. Ill need to get these as well to keep the corrosion down.
Jeff
Jeff
