centrifugal slinger
freddyray21
Just curious what the purpose of it is. I replaced the impeller on my Mercruiser tonight and forgot to put it on. I'll have to pull it off again to put it on and I will, but was just curious what it did.
Bt Doctur
Re: centrifugal slinger
My theory is that it helps keep exaust gasses from entering the pump body when the pump is not covered by water (on plane)
DHPMARINE
Can you explain a bit more ? Does your manual call it a slinger ?
DHP
freddyray21
yes the online manual and the parts manual both call it a slinger. It sits on top the water pump on the shaft
