89 resorter
- Joined
- Oct 3, 2013
- 287
Here are the pictures of the oops that I put through the hull before I learned how to grind more better along with the dock rash that I will need to fix from the PO before he learned to dock more better
Both cuts through the hull are located at one of the chines where a stringer will bed down
Here are pics of the dock rash on the bow and the same location from inside the boat. I originally thought that the inside was badly damaged until I got a closer look to realize that the big gap is only the area where the inner hull with the balsa core sandwiched ends on each side. Still, I will be interested to get opinions on how to fix it since it is only about one inch wide (at its widest) and about 3/8" deep so I am sure getting glass into it will be a challenge.
My plan is to go with epoxy for the transom then use poly for the rest of the build. Seeing how I will run out of warm weather before I can possibly get it all done, I plan on getting the transom done this fall, focus on building stringers and interior over the winter, then pick back up in the spring to finish bedding and glassing the stringers and floor. This way I can order and use all of my epoxy stuff now then wait for spring to order all of my poly supplies. Now for my challenge ...... all of the threads that I have followed have used poly so I have no idea of what to use for the transom (what is the PB mixture, type of glass mating, etc.). WOG, I would also like to know more of the vacuum bagging process you pointed out.
As always, thanks for all the help.
Dave.
Dave.
