I have a Johnson 70hp from 1986, engine code: J70TLCDC, and wonder if it might be time to change the impeller. How often should it be replaced?
Is it enough to replace only the impeller, or should I go for the "water pump repair kit"?
How do I replace the impeller, do I need to remove the whole gearcase or is there a short cut?
How do I know if my engine is 49 cid or 56 cid?
