Easymoney305
Thread starter- Joined
- Nov 14, 2022
- 3
How to change steering shaft and Gimble ring without pulling motor on pre alfa drive alfa 1 and 2
pulling the motor is the best option.How to change steering shaft and Gimble ring without pulling motor on pre alfa drive alfa 1 and 2
I would have had the drive off and the motor out and back in in the time it took you to do all that.Im in the process of changing the steering upper pin and shaft as we speak on my 78 silverline nantucket the parts showed up today. Now not everybody can do what im doing. I took a drimmal and cut the back plate above them Gimbal ring below the geese zerk where its says mercruser make the cut 1/4 in from the bottom of the recess and follow the lip up the sides and top remove plate you will have to eather make your own wrenches but you can get to the nut and pinch bolts and take it apart. When it time to reassembles it. this is what im doing I cut a piece of 1/8 in alum plate shaped it to fit what was removed it know how to Run a mig so im welding it back you must keep it cool and only weld short intervults and let it cool now if you get it all ready to weld find a welding shop and have them weld it on for you it beets pulling the engine. Just make sure its clean so they can weld it
Yes. I was intimidated by the thought of an engine pull. But I had to do it to replace broken front mount studs. The worst was bolstering the garage trusses so I could hang a come along chain hoist. The actual pull/replace was easy. I used the set up to help my pal pull his 350 Mag to replace his engine coupler.I would have had the drive off and the motor out and back in in the time it took you to do all that.
