Motormaniac801
- Joined
- Jun 6, 2010
- 27
1974 glastron bayflite. 140hp Merc i\o. The lower is the r series.
Just replaced the impeller(water pump)(it was pretty ugly), pulled the lower off in neutral so it would be easy to put back on. went to put it back together and check the gears and FNR all matched up. but then I noticed I forgot the bolt on the inside for the fin above the prop. so I had to pull it back off. in my efforts i must have spun the prop and also the receiving end of the shift bar on the upper. Now I cannot seem to get the gears to match up no mater what i try.
I lowered the trim all the way down cause I hear the gears "fall into place".
