mnypitboat
- Joined
- May 31, 2010
- 1,091
Re: Changed my brakes, now I got a shimmy, kinda bad...
You are lucky. We have a machine shop that can do it, but they charge $30 each. Tire Kingdom is around the corner but they are the ones that screwed mine up. Hopefully the OP has something around there. I just dont see the point in turnin old rotors that are possibly marginal when brand new ones are so cheap.
PS absolutely no parts stores turn rotors anymore. At least not around here.
When all else fails, buy a harbor Freight dial indicator and measure the runnout on your rotors. You can also index your rotors(rotate them on the studs) to get the least runout if you are really anal.
I would get the rotors turned if I were you. On some vehicles, there just isn't enough meat on the rotors to get them turned. Silverados are not one of them. There are plenty of machine shops, including those at auto parts stores, that turn rotors. I have at least a dozen of them within 5 miles that do it.
I also would not buy the cheapest rotors you can find. I actually bought a bad brand new rotor verified by a dial indicator.
