changed rectifier with no results
dieselcat
Ok,a few weeks ago i inquired about my tach not working.someone responded with a link as to how to test for bad rectifier,i tested it and bam,the tach worked so i bought a new rectifire and in stalled it today.Started the motor with new rectifier in place and tach still does not work.Any idea why it still is not working?will it hurt to change yellow wires around cause new ones are not marked with grey stripe like originals where,they are just solid yellow.
Barnacle_Bill
Re: changed rectifier with no results
Did you test the stator too? The yellow wires are interchangeable.
Joe Reeves
What's the model number of that engine?
dieselcat
The model# is E88TSLEOC
Also i put a test light on both yellow wires. on the first 1 from top of connector bar as the motor would rev up and down the light would brighten and dim.and on the lower yellow [the second wire]i would get nothing.
