You may...
But your motor is the best one to answer the question. First off make sure your motor is in good tune, and has no running issues. Install it on the pontoon boat. If your motor does not have a tachometer, you will need to get one. Something like this will fit the bill;
http://www.amazon.com/Tiny-Tach-Hour-Meter-TT2A/dp/B0045L9GA0
Throw the boat in the water, and open the engine up to WOT, observe the tach. Your engine should be able to reach the specified WOT RPM range. If it falls short, you will need to drop the pitch of your prop accordingly, so the engine is able to get in the proper RPM range at WOT.
