lowkee
Thread starter- Joined
- Dec 13, 2008
- 1,890
Well, I'm back at the boat after my trip and a much needed break. Before I left I painted one side of my 20' fiberglass hull, using the roll and tip method, with Pettit Topside paint. After letting it cure for a good 3 weeks, the outcome is questionable. Now I need advice as to how to proceed..
The pettit didn't seem to fully harden for some reason and is soft enough to allow fingernail dents, and I have already scratched right through the paint in a few places, just by carefully moving the hull around. The real bummer of this paint job is I can't sand it, since it just gums up my sandpaper almost immediately. What can I do to fix this?
Steps I have taken and options I have (so far):
I plan on putting a pearl clear coat over the topside paint, not for protection, but for looks (the pearl additive needs clear coat). If I can somehow smooth out the orange peel on the topside paint, I would be able to have the clear coat be a protective layer to prevent the crappy pettit from scratching. However, upon painting a computer case (practice) with the pettit using a sprayer, then coating the pettit with the pearlized clear coat, the clear coat curdles the pettit just like milk in places!
At this moment, admittedly I haven't fully thought this through, I am considering dumping the Pettit paint and buying automotive base coat, something I know will play nice with the clear coat. That, of course, means sanding off the paint (or using paint stripper!) on the already painted side of the hull, as I can't risk the paint curdling when the clear is applied. The sand paper alone on this task is costing me a fortune, and my arms are about disconnected from my body at this point.
This is a serious issue.. the Pettit won't fully harden and scratches super easy, but the clear coat eats away the Pettit! Keep in mind, only 1/2 the hull is painted, so do I continue forward and paint the other side or remove the paint from the painted side and start from scratch? Either way, I'm looking at a ton of work and have no idea how to proceed. Any ideas?
