Changing colour of gelcoat question
carlos515
What wood would be good for the motor mounts? I was thinking Douglas Fir. Or should I just laminate Baltic Birch ply together on the flat?
carlos515
Made some progress today. Cutting the floor tabbing, and removing the bulk head under the drivers' podium.
carlos515
I have 6x18" long by 2" high ribs on both sides of my keel. They do not join to the stringer. The wood has long since rotted away, leaving a fibreglass shell. Could I replace these with an upright stringer to join the hull to the floor in its place?
MikeSchinlaub
In pictures on the previous page, I can see what look like small boards glassed in place and running sideways between the stringer and verticle side of the hull. Are these what you're talking about?
MikeSchinlaub
I don't see why you couldn't do a stringer there instead. It's going to be pretty small though.
carlos515
Thank you, the stern ones are larger than the bow ones. I was just worried that the hull would be too stiff.
carlos515
Well I just finished tenting my boat. The exhaust air supply is hooked up. Now to start removing stringers and grind.
carlos515
I lifted the boat off the rollers, the rollers were indenting the hull. I think removing the wobblers and turn the trailer into a bunk trailer.
carlos515
More progress this evening. Removal of the section to join floor to motor mounts basses. I certainly am not happy with the quality of the ABX ply that I used. Not sure if it is Auruco. I did not buy it at the Depot.
carlos515
Still water under some foam. Will let it dry, some 4.5 inch diamond blades are in on order. I use them to cut the fibreglass. They work extremely well.
carlos515
While I am removing my stringers, that I installed 3 years ago, I am getting delamination big time. I had ground, wiped with acetone and glassed with 1.5 oz mat and 1708.
What should I do differently this time? Last time I worked outside. Now the boat is in the garage.
Got a pic of how far you ground down before tabbing last time?
Most people stop grinding too soon
carlos515
Yes, I stopped too soon.
Looks like my transom is coming out now.
Nowhere near enough grinding. Should have gone another 2-3 mm deeper and about 8" out
carlos515
Thanks, Scott.
Just glad I am redoing the job. I will take my time this rebuild. I do not have to rush on account of the weather or season change.
carlos515
Well, the easy part is done. Now the harder part, to remove the front stringers and the leftover material. I was thinking of a 4-1/2” Compact Circular Saw, to cut the stringers to near the hull. My 6-1/2" is too big.
