phillnjack2
Ensign
Thread starter- Joined
- Apr 30, 2011
- 918
EVINRUDE 60HP
YEAR 1995
MODEL NO E60TLEOC
OVAL PORT 56 CU IN.
cylinder compression with cold dry engine top 149 - middle 147- bottom149.
At present I get 5900rpm with a 13x19 sst and max speed of just 42.3 mph.
I make that a slip of just around 4%, that I think that is very good with a gear ratio of 2.42-1.
so far so good as the engine is very near the top of its power band and getting around 60hp at the prop.
my engine is a 1995 evinrude 56cu in oval port, and with the smaller venturi carbs that make this the 60hp version.
BUT
I want more power and more top end from this engine, so I am upgrading it to the 70hp version by changing carbs.:rockon:
All three carbs for the 60hp are just 1 1/4 inch venturi, and carbs for the 70hp are 1 1/2 inch venturi.
The larger venturi gives a extra 44% larger volume area than those for the 60hp, and this is where the 70hp is
restricted to being a 60hp engine.
This restriction was the only difference between the 60 and 70hp versions of my 1995 evinrude triple.
ive checked out all the other part numbers for pistons, porting, exhaust, tuner, power pack, timing etc.
i know 100% that the engine can rev to atleast 6400 rpm when i used a smaller pitch prop (13.5x15 alloy)
By using the larger 70hp carbs i would be increasing power by 16% !!! (60 to 70hp)
would this be enough to give me another 500 or so rpm's.
YEAR 1995
MODEL NO E60TLEOC
OVAL PORT 56 CU IN.
BUT
