Re: changing long to short shaft
On the fifties and sixties Johnnyrudes, the conversion from longshaft to shortshaft was easy. You needed a new short driveshaft and a shift rod connector. You then removed the midsection extension, driveshaft cover, and water tube extensions, and installed the new driveshaft (simply pull out from the gearcase) and shift rod connector.
