changing long to short shaft
412lorie
is it all possible to change long shaft to a short shaft. is it a major production if it can be done?
roscoe
Re: changing long to short shaft
It depends on the make, model, and year of the motor.
tashasdaddy
changing drive shaft, water tube. can be major. get a jack plate like i said in the other post.
Solittle
With my 12' tinny with a 9.9 longshaft I didn' bother - runs just fine - could run better with a short shaft but not woth the bother to me.
jspringator
When I was shopping for my motor on e-bay, I noticed several incomplete conversions for sale, all in various stages of disassembly. If I couldn't make the long shaft work in my application, I would sell it and get something that would work rather than take it apart.
On the fifties and sixties Johnnyrudes, the conversion from longshaft to shortshaft was easy. You needed a new short driveshaft and a shift rod connector. You then removed the midsection extension, driveshaft cover, and water tube extensions, and installed the new driveshaft (simply pull out from the gearcase) and shift rod connector.
