powderman1
- Joined
- Sep 29, 2008
- 2
Just wondering how I get the old oil out. It doesn't have brass fitting on the dip stick for my pump. Is there a plug somewhere or do I need some other style of pump to remove it?
I also found that you do not get all the old oil out when doing this. Tilt the motor back down after replacing the oil drain plug and then back up and you will find you get another quart of oil to come out. First time I did it could not figure out why it only took a little less than 4 quarts to fill it.
