Changing my gas type on my outbord
mcgill
Hello'
i have my motor running well now . But i am thinking of changing gas form 87 to 97 will is this save gas. Also i am now cleaning my go spark plugs untill thy go bad. This will save my money. It is graet haveing a boat and motor that runs well
thank you
Silvertip
Re: Changing my gas type on my outbord
You will not save money by changing from 87 to 97 octane. It does not make more power, it does not make better fuel economy, the additives can possibly muck up a perfectly good engine, and for sure, it will drain your wallet. Since you are interested in saving gas, you must also be be interested in saving money. So the lesson here is to stay with 87 octane which is what the engine was designed to run on. Higher octane is needed ONLY when an engine design requires it (as in high compression engines).
Bifflefan
^^^^^^^^^^^^^^there is the best answer you will get^^^^^^^^^^^^^
skrillz78
I agree with first post.Always use the manufacturers recommendations.
robert graham
If fuel economy is an issue then go to: Yamaha Outboard Performance Bulletins, plug in your boat/motor type, and get information chart on GPH, MPG,MPH for your set-up. That way you can cruise at the most efficient RPM range. Like for my rig,3500RPM's is the most efficient cruise. Good Luck!
paultjohnson
Hello'
thank you
97 octane ! holy crap !
greyrob
thats racing gas - the highest around here is 93 - 105 is at the track
stay with what they say
