Changing my Gear Lube
chicubs08
Can i leave my alpha 1 out drive without gear lube ? I emptied the outdrive gear lube but the store is closed to go buy gear lube. I will do it tomorrow morning. Can i leave it without gear lube? Thanks
conk3416
Re: Changing my Gear Lube
Yes it will be fine to leave your outdrive without gear lube. As long as you DON'T run the engine without any gear lube in it.
jaxnjil
correct-- let me add i like to leave mine drain over night when i change oil.
rember as stated above; your alpha drive turns when ever your engine turns
