What kind of a job is it to change a prop on a 1995 90HP force?
C cousineddie Cadet Joined May 4, 2008 Messages 11 May 29, 2008 #1 What kind of a job is it to change a prop on a 1995 90HP force?
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,854 May 30, 2008 #2 Re: changing prop Pretty easy. You need a wrench, a 2x4, and a little glob of grease.
C cousineddie Cadet Joined May 4, 2008 Messages 11 Jun 1, 2008 #3 Re: changing prop Thanks. Is there a torque spec for the nut or just tight?
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,854 Jun 1, 2008 #4 Re: changing prop I think it is 60-80 ft-lb tight is good, just make sure you use the proper hardware including the tab washer to lock the nut in place.
C cousineddie Cadet Joined May 4, 2008 Messages 11 Jun 3, 2008 #5 Re: changing prop Thanks for the help.
