changing rudder & driveshaft packing
circle hook
Hello I have a 32foot luhrs i just bought its still on land but i need to change the packings before putting her back in the water any advice on changing them would be a great help the rudders seem to be ez to see but the driveshafts are in the back & ubder the transmissions looks tuff to get to. any help before I start would be appreciated, tools packing material etc. anything I may run into problems Thanks Bob
circle hook
Re: changing rudder & driveshaft packing
how do you know your tight enough do you tighten all the way down and then back off 1/8 to 1/4 turn as so not to be to tight Thanks Bob
salty87
exactly, then monitor for a drip/minute in gear. if none, loosen a bit more. if more, tighten up a bit.
