Re: Changing temp gauge and sender
If you are talking about the water temperature sender, then I think Don is exagerating a little (shouldn't mess with it comment!)!! The sendor just screws into the engine (usually near the thermostat housing) so its not difficult to change, just be very carefull tightening the new one as you can damage them easily by over-tightening. The gauge is also not difficult to change, even if you are not mechanically inclined I would not consider this a difficult job. Why are you changing the sender and gauge? It's rare that the gauges go wrong? If something is not working you should be asking for advice on how to find the faulty part then replace it, don't just change everything in the hope to fix the problem.
Gary
