changing thermostat
torcano
When replacing the hoses that go to the thermostat housing, is there any special sealant needed or is just putting back the ring clamps sufficient?
Thanks
gcboat
Re: changing thermostat
Some guys will use Permatex others don't. I just double clamp mine and have never had an issue with them leaking. My .$02
speedmerchant
Put them back on as normal with the clamps. A good tip is to remove any rust/scale on the inlets with a wire brush and clean the inside ends of the hose. All should be good. Using a sealant on the hose connections will just make for a messy and hard time when you want/need to take them off again.
