Changing trailer lights...
C-17 Pilot
:facepalm:
Maybe it's time I hit the weight room a bit more, but I cannot seem to displace the red lens from the white end. I've tried brute force, enough to where I don't want to break anything, I've tried sliding it, and I've looked for screw holes? None.
Any advice on how to get to the brake lights on the trailer? I simply need to replace the bulb.
Thanks
wifisher
Re: Changing trailer lights...
Hard to say without knowing what kind of light it is. Maybe a pic?
ktrahan75
You cannot remove the red lense. It is all one piece. You can go to your local bass pro, academy, or dealer for a replacement. Should only run you about 7.00 for a new light. There is only one bulb inside that acts as a brake and signal light. Hope this helps.
