FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
When changing the water pump in an Alpha I Gen II which way should the impeller fins be pointing if you are standing over the prop end of the drive looking foward, or does it matter.Thanks
If I am remembering correctly it should spin clockwise so the fins should be bent. If your drive is upright standing infront of it with the prop facing you at 12 clock position it should be bent to the left
Simply turn the vertical drive shaft clockwise as you push down on the housing and they will go it right. USE some silicone spray or soapy water to lube them.
