charging 24V
pootnic
I have 2 batteries in series(24V).
I have 2-12volt chargers.
Do I have to disconnect the batteries(+..-)making them 2-12 volts,to charge?
and If I bought a 2 bank charger would I have to seperate the batteries to charge?
I'm thinking I don't have to,for each situation because they are seperate circuits when charging,,am I right?
Silvertip
Honorary Supreme Mariner
Re: charging 24V
Your plan is ok with one exception. If you buy a "used" 2-bank charger, make sure it has isolated grounds. If the charger has two Positive leads and only one negative lead, you cannot use it on a 24V system usless you break the jumper between the two batteries. If the charger has two positive and two negative leads you are good to go.
pootnic
Re: charging 24V
Thanks for the quick reply.
I'll watch out for the seperate grounds.
