Charging boat while on the highway.
Halifax Shipfaced
Re: Charging boat while on the highway.
Wow alot of input, thanks.
The reason for wanting to charge the boats house batts / keep the fridge always on is because we will use the boat as our camper and use truck stops for rest time. This will be often, (min 5 days and could be twice as much depending on weather and our 3 yr old) as we are only allowed to tow from sunrise to sunset because of the "wide load" restrictions.
Once dark (Sunset around 5pm) will want to use the lights and stuff before bed time.
The boat already has 2, size 27 dedicated house batteries, a built in charger and can easily run the fridges 12 HRS. But since we will not expect to be plugging in anywhere along the way we need additional power.
I seen your ARC answer and JUST erased the options I was considering as this sounds best.
Thanks Bruce.
I guess it doesn't make any difference which one to hook upto since the truck and the boats 2 batteries are connected in parallel.
And the plan will be the 30amp/ 10g - thanks Bondo
spdracr39
You can consider using solar panel to charge the boat battery
How about a big windmill on top
Or even one of those generators like they use on a bike tire :)
TerryMSU
Has anyone else considered the implications of running 110 VAC across the trailer hitch? What if something gets pinched or otherwise shorted. The whole vehicle train (Tow vehicle and boat and trailer) could be at 110 volt potential. I see a BIG lawsuit coming if something goes wrong. I also see your insurance company denying coverage. I would not recomend passing AC from tow vehicle to trailer when the system is under tow. Have you considered a small generator? I have seen a small 1500 watt Honda unit that might be a good option.
TerryMSU
