Hello I have a 1996 Johnson 130HP outboard and it does not seem to be Charging.<br />I have replaced the Rectifier and the Stator and still I only get 11.9 (DC) volts or 12.0 (DC) volts at the battery and on my deep recorder and also at the solenoid ( it shows the volts).<br />I have checked and triple checked the wire's and they are all hooked up right and none are bad the Battery cables are only 3 weeks old and the battery's are not that old maybe 4 months.<br />This thing is driving me crazy what else could be wrong.<br /><br />Also I tried measuring the volts that came from the Yellow stator wire and only got 6.0 DC Volt's is this normal.<br />And in the in the factory manual it says that the magnet's in the flywheel could be bad how often does this happen.<br /><br />Thanks<br />BadBoy
