Re: charging Issues
My fish finder Has a Volts display and it reads dead on what my meter reads at the Engine solenoid.<br />I have Also replaced the Battery and still Nothing<br /><br /><br />Tanks<br />BadBoyOriginally posted by Seasport:<br /> I think it's a 9A stator Jim. Yes and of course you don't open the circuit while the motor is running. You hook it up and then run the motor.<br /><br />I come back to the question - how do you know the battery isn't charging Badboy? Is there any other evidence other than your voltmeter reading? Does your battery go flat? Just maybe your voltmeter is reading incorrectly. Have you tried reading the battery voltage with another meter?<br /><br />Infinite ohms will give you the same reading as if the meter probes are sitting in mid air, i.e. the meter will do nothing.<br /><br />Are you sure you have hooked up the regulator the right way? Have you checked the stator windings have no connection to ground? You've replaced everything in the circuit except the battery. Maybe you shoud try another battery!
