Charging output
da83moon
1979 evinrude 55 hp engine. I was wonderng when I'm run aver 3000 rpms and especially when I'm running 3/4 throttle on up it show charging volts @ 15-16 is this supposed to be this high??
Thanks IN advance andy
tashasdaddy
Re: Charging output
yes, because it charges very little a low speeds.
da83moon
Re: Charging output
Thanks tasha one more that I should have added was when I'm starting the engine and when the key goes back to the run postion, as the starter disengages it makes a whooo sound. It be like, ringggggggg to start and then when I let off the starter it sometimes goes wooo.. Any ideas on the cause?
Silvertip
Re: Charging output
Must be an "oriental" starter. Sorry -- couldn't resist. The ringing sound is the starter bendix (the starter gear) meshing with the teeth the on flywheel which is sort of normal. When you release the key, that noise may be a dry bushing in the bendix or dry bearings in the starter motor.
F_R
Re: Charging output
I can hear it now. Dry bearings in the starter.
da83moon
Re: Charging output
Thanks all any worries on this, and if so what should I do to fix... I thought about posting one of the car guys examples as an audio file... however didn't want to scare any small children.
