charging problem 1979 johnson 100HP
eaganboater1
I think i have a charging problem on my 1979 johnson outboard. i'm hoping you can help. here are the symptoms:
the battery has died twice inside of two months, (once leaving me and my daughter stranded on an island in the missippi :<
the tach doesnt work
after running the boat at 3/4 throttle for close to an hour the battery still doesnt take a charge
after putting battery on external charger, it keeps a charge for a month or so
i DID connect the battery with reverse polarity before all this happened and tried starting the motor
i tested the rectifier ( a 3 wire version, 1 red, 2 yellow) as follows
using a multimeter with a diode test setting
connected yellow #1 to red lead, black lead to base overload
" " #2 " " overload
" red wire to red lead, black lead to base - overload
reversed leads
yellow # 1 .518 volt
yellow #2 .481 volt
red overload
is the recifier bad?
dr1553
Re: charging problem 1979 johnson 100HP
It's my understanding that if you hook up the battery backwards that your rectifier is toast. You can get a Sierra brand aftermarket off of ebay for around $20.
F_R
Honorary Supreme Mariner
The tests are:
meter leads to yellow and base. Should show either a high or low reading. Reverse meter leads and result should be opposite from the first.
Repeat with other yellow lead & then reverse the leads
Repeat with meter leads to yellow and red & then reverse the leads
Repeat with other yellow and red & then reverse the leads.
As you can see it must pass all 8 tests. If it doesn't, it is junk.
However, if you connected the battery backwards, save your time. That will instantly destroy one or more of the diodes in the rectifier. You can't disconnect it fast enough to prevent damage.
eaganboater1
thank you everyone. i appreciate the help!
