madman2021
Thread starter- Joined
- Dec 17, 2010
- 175
I've been working on this for a while now and need to get some help. I am trying to charge my trolling motor battery with my mercruiser 140 engine alternator. I have a solenoid rigged up to connect both the main battery and the trolling motor battery only when the key is on and engine is running. When the key is turned off the trolling motor battery is disconnected from the alternator circuit and the main battery. I used a trim solenoid for the power trim thinking it was going to hold the current but it's getting really hot. What solenoid could I use instead. The trim solenoid I used was an old one I pulled off when I replaced my trim solenoid. Any help to improve my design is much appreciated. Thanks.
