charging
becron
I bought 2 energizer E29hm deep cycle batteries they had 12.4 volts in one & 12.2 in the other ,i put my noco 3 bank 30 amp 10 per bank battery charger on them & they are up to 14.50 & 14.47 my question is how high should they go before it shuts off ,they 125 amp hr ,840ca, 675 cc amp. thanks
Well it finally stop charging & it showed 13.52 on one and 13.36 on the other ,I guess i should have check it when it wasn't charging ,i was getting a little nerves but i didn't take in concideration that it was still charging when i was checking it ,The charger did it's job ,it was the first time i had used it since i bought it . it work very well.
dwparker99
Re: charging
If the voltage is 13.52 & 13.36, they are probably still charging. If yours is like my Noco Gen 3, just because the light goes from red to green does not mean it has finished charging. Watch the voltage for a couple of minutes, if it is climbing or is dropping and then starts to climb, it is still charging.
