KTglastron
Thread starter- Joined
- Mar 31, 2010
- 3
We're befuddled with a nagging oil leak on our 205 Glastron S/F. Can't determine exact location and am ready to pull the engine. All good knowledge from history with this engine and troubleshooting advice is most welcomed. OK, specifics and background:
- The engine is a 1998-99 4.3GI PWTR.
- Maybe 500 hours on it. It goes out ~20times/year, freshwater.
- oil is dripping from the back/transom end of the engine only
- it developed ~2 years ago (after over-filling with oil by 1/2 qt...coincidence?)
- the leak into the bilge is evident ONLY after running it for the day and back on trailer
- for ~1yr, it was maybe 2-4 tablespoons leaking after each trip
- 5 months ago it went to ~10tablespoons/trip
- a year ago, we cleaned the engine and added UV dye to oil
- ran it several times, climbed into the compartment with black light(s), mirrors and such, and never found a pinpointed glow....but oil was there. Added more dye, still the same thing.
- leak is always at the rear of the engine, above oil pan, and it seems about half way up
Gotta fix it.
While we hope it is NOT the rear main seal (..and doesn't that leak typically during operation), we can't find experienced intel on other possibilities, like: oil sender, PCV clog, distributor housing gasket, oil pan gasket, etc.
Before we pull the engine, I'd like to get your feedback. After we pull it, we will put it on a stand, clean it, run it, find it, and fix it. Any procedural items we should know with this engine? and 205 Glastron S/F? I downloaded the shop manuals (thanx iboats.com!) and have a GoodWrench friend to help.
Thanks much for your time and considerations
Gotta fix it.
