- Joined
- Jul 23, 2011
- 52,783
Re: Cheap Go-fast parts (vortec head swap)
the sucking sound is the secondaries
once you get your motor healthy and if you want to go from there with performance increases, my recommendation is as follows:
vortec heads with stainless valves (look on racingjunk.com - its end of racing season, people need money for x-mas gifts)
vortec manifold - ebay or elsewhere. if your in salt water, stick with cast iron or aluminum bronze dual alloy intakes. if your in fresh water, aluminum is fine.
1.52:1 rockers
I also recommend a cam change. Do not go above 268/270 degrees duration with wet exhaust. stick with a marine grind
new timing set
brand new melling oil pump, pump shaft, and pickup
New gasket set
1.52:1 rockers
new timing set
New gasket set
