I recently bought my first boat with an I/O and it has a Mercrusier 4.3L V6 Thunderbolt engine and is a 1995. There is a primer bulb in the fuel line which needs to be used to start when cold. I've been told by several that it is not suppose to be there so I took it out and ran a straight line. I couldn't get gas to the carb so I put the bulb back in. I've been told that there is a check valve to keep the fuel from draining back into the tank and is probably not working and it is why someone put the bulb in. Anyhow, I've been told that this check valve is in the carb and I've been told it's at the outlet from the fuel tank. Which is it? And any other ideas????
