Re: Checking Compression 1991 60 hp Johnson
You will need a socket and ratchet to remove the spark plugs, and a compression gauge. Remove both spark plugs and ground them somehow (i.e. clamp to the block, AWAY from the holes). Put the gauge into one spark plug hole (it will screw in just like the spark plug did), and turn the motor over. If pulling a cord give it a few pulls, if electric start a second or two should do it. The gauge will go up and settle on a #, that is your compression. Write it down, and repeat the steps for the other 2 holes. What it should be varies, but generally they should be within 10% of each other (the highest and lowest #'s should not be more than 10% difference). I have a 1993 60hp and mine were 118psi. One was a bad cylinder and was only 80psi. Like I said, the #'s can vary by gauge, some read higher, some read lower, most important is to be within that 10% range. If a # seems way low, just ask us and we'll let ya know.
