Checking for H2O
kmongar
a couple of simple questions but I am unsure so better ask:
(1980 898, was 305 now 350, 2bbl)
1) How do you check for water in the fuel/water filter...just empty it into a bowl and see if the phases separate?
2) How do you check for water in the cylinders? Spark plugs are not rusty.
Don S
Re: Checking for H2O
Yep, that's it. Using a clear container makes it real easy to see.
Pull the plugs and bump the starter over a little at a time. it will squirt water out the plug holes if there is some there.
Now, Why are you asking????? What is your problem?
Too many times I have seen people asking questions like this only to find the real question and problem had nothing to do with the questions ask.
Haut Medoc
1) Yes.....& replace it anyway.....
2) Remove the plugs, ground the wire that runs from the coil to the dist., crank the engine.....
No rust on the plugs is a good sign......:)
kmongar
Don, Haut...thanks for the replies.
Refer to the "Mercruiser 898 cutting out" thread. It is 12 or 13 threads below this one.
