Hello. I have an old Volvo Penta AQ131A, with a 270 outdrive, which is not sucking in raw water
. I have replaced the impeller and if I poor water into the raw water filter, water WILL come out of the Exhaust port. I'm going to check for air leaks in the intake system and I just wanted to know, if my problem is the seals on the lower drive, is it removable ,without taking the whole stern drive apart, so I can replace those seals around the raw water input?
Thank you
for answering my first post
Thank you
