Re: checking valve clearance
I finnished the job by bolting a piece of 1/4 felt pad inside the rocker cover.
Strange way to fix worn rocker shafts.
<br /><br /> <br />
coldwaterboater,<br />As per Honda Marine Shop Manuel.<br /><br />Valve clearance inspection must be performed with the engine cold.<br />1)Remove the engine cover.<br />2)Move the gearshift lever to "N" position.<br />3)Remove the four 6x25mm flange bolts and three 6mm plain washers from the flywheel cover.<br />4)Remove the flywheel cover.<br />5)Disconnect the breather tube and oil return tube from the cylinder head cover.<br />6)Remove the sparkplugs and the engine hanger bracket.<br /><br />
CAUTION! <br />.The starter stopper collar is close to the flywheel and the starter ring gear can become sharp. Avoid hand contact with the starter stopper collar or flywheel ring gear.<br />Hold the upper portion of the flywheel when rotating engine.<br />.To avoid waterpump impeller damage, always turn the crankshaft in a counterclockwise direction.<br /><br />7)Manually turn the flywheel counterclockwise in the same direction of the arrow on the flywheel. Align the "T" mark on the flywheel with the "I" mark on top of the engine hanger mounting boss. The "Tv" mark on the cam will align with the "T^" mark on the cylinder head. In this position the No.1 piston is at top dead center of its compression stroke.<br />With the engine in this position, check the intake and exaust valve clearances of #1 cylinder by inserting a feelers guage between the valve stem and the adjusting screw on the rocker arm.<br /><br />
Valve clearance, <br />IN. 0.13-0.17MM (0.005-0.007in)<br />EX. 0.21-0.25mm (0.008-0.010in)<br /><br />8)Turn the flywheel counterclockwise until the cam pully turns an additional 120deg. and the "^2" mark aligns with the "T^" mark on the cylinder head. This will put the No.2 piston at TDC of its compression stroke. Check the inatke and exaust valve clearances on the No.2 cylinder.<br />9)Turn the flywheel counterclockwise until the cam pulley turns an additional 120deg. and the "^3" mark aligns with the "T^" mark on the cylinder head. This will put the No.3 piston at TDC of its compression stroke. Check the intake and exaust valve clearances on the No.3 cylinder.<br />10)Proceed to adjustment if necessary or install the removed parts in the reverse order of disassembly.<br /><br />
Adjustment <br />1)With the cylinder at TDC of its compression stroke, loosen the adjusting screw lock nut, and turn the adjusting screw to obtain the specified intake and exaust valve clearance.<br />2)Hold the adjusting screw using a screw driver, and tighten the lock nut.<br />
Torque:23Nm (16.6 ft-lb) <br />3)Recheck valve clearance after tightening the lock nut.<br />4)Install the removed parts in reverse order of disassembly.<br />-------------------------------<br />If your going to miss a valve adjustment check, the intial 20hr isn't the one to miss. This is the break-in adjustment.<br />Checking valve adjustment deserves alot more attention then what brand oil you're using.<br /><br />I adjusted my valves at the recommended intial 20hr. service interval. I adjusted a loose #3 exaust valve clearance. At 100hrs. I adjusted a loose #1 intake valve clearance.<br />At 200hrs. no adjustment was needed.<br />
They will be checked again in another 10 or so hours, at 300 hrs.<br /><br />Valve clearances tighten substantially at cold temperatures. A valve with tight clearances on a 70deg. day is one thing. That same clearance goes away on a 20deg. day. Immediately resulting in a terrible coldstart and rough running while the engine warms up.<br />A common complaint with the BF50.<br /><br />BTW, my cambelt needs and gets an adjustment pretty regular.<br />It's a very simple proceedure also. <br />Buy the FSM.
