81 Checkmate
Thread starter- Joined
- Jul 20, 2010
- 1,360
Seeking out advice from the experts. Bought a small block 350 for the Checkmate. It had the 898 -305 in it and I am upgrading to a 350.
When I bought it I did not see it running! (I know you should never do this)?....but i realy liked the old guy..... and I tend to believe him. He said it had around 80,000 miles on it and came out of a C-20 Van.
Anyway?..
Here is what I have?.
Block ? 3970010?? 020 by oil filter
Numbers on machined block left front ? small numbers ? C5U182033, Big numbers ? V0701 TYU
Head number - 333882
By decoding I think I have a..
1975 ? 4 bolt main
165 HP
8.1 .1 Comp
882 heads that are prone to cracking with the center port exhaust passages
So we pulled the Valve covers, Intake, Heads, Oil pan??? Center ports on intake clogged with combustion crud? but the piston walls and bottom end look great to me!
Now to my question? As always im a penny pincher, still need a lot more money to finish restoring the boat?I want to get more HP and Torque out of this motor..Would like to keep it in the $300.00 range. Minus the gasket kit which is around $120.00 for the fel-pro.
I already have-
Summit Cam and Lifter set ? K-1102?Lift 0.420/0.44 ? Duration 204/214
New double roller timing chain
And I can get a set of used 3973487 heads for $75.00 Are they worth the trouble?????
Ok give me all your opinions on what to do.
Thanks!
Anyway?..
1975 ? 4 bolt main
165 HP
8.1 .1 Comp
I already have-
Thanks!
