JT!
Thread starter- Joined
- May 19, 2008
- 260
the kicker motor runs fine on the fuel. the fuel dock is 100ft away, I will add a few gallons of fresh.
I noticed 2 things today: the electric choke wasn't hooked up, and its connector had a loose fit. -- I cut it off and crimped on a new terminal
secondly, the choke plate is near wide open. im going to need to make sure it shuts flat when the ignition is turned on.
how many times should I be pumping the throttle (only figured that out today) tried 5, 10, 20 times. I hear like a dry spritzing sound.
not sure fuel is making it to the engine, however I do smell fuel when I try to start it.
back at home charging up the 2 main batteries to full before heading back tomorrow.
